Cruise control
t.rider.013
2000 f350 7.3L Cclb Cruise control worked intermittently than all of the sudden stopped working. Where should I start looking? Checked all fuses. All look fine lights work, no fault codes on dash. Any suggestions?
Mesa, AZ
Cancel switch on the master cylinder. There was a recall on them leaking, and causing fires. Could be the fuse in the jumper harness that was installed, if the recall was done, or the switch couldve failed.
