strokin'_tatsch
Helping a friend clear up some shop space. Most parts are used. He installed most of this stuff on his truck and decided he wanted to take it all back out and redo it using mostly destroked parts.
$600 OBO for everything. I would like to get rid of everything together. Some of this stuff wouldn't even be worth shipping by itself.
Ford-Cummins bellhousing adapter for 12v to 4R100. Comes with spacer to go between adapter and engine and starter adapter to use 12v starter. The adapter plate was modified to accept a bolt in freeze plug on the rear of the engine.
Ford-Cummins flywheel. 12v to 4R100.
Front and back bolt in freeze plugs for 12v. Installed, but engine never started.
New voltage regulator. Allows use of 12v alternator, but stock ford gauge will not work.
Moroso universal overflow bottle. I don't have the part number for this yet, but I can try to get that if needed..
Sent from my SAMSUNG-SGH-I337
