Goose
Post what you have done. Reg returns, bowl delete, sump, cooler......
Stuff besides an AD2
Hellman sump, DAHL 200, Aeromotive 11110 Marine pump, Aeromotive SS filter, Russell "Y" block, Aeromotive Marine HP regulator, Fuel cooler, check valve...various insulation sleeves, and covers, etc.
-No stock lines, stock fuel filters and pump removed, no banjo bolts.
-All lines are -12, -10, -8, and -6 braided stainless steel.
Ivan is that bracket in the second photo holding a turbo!![]()
Are the 6.0 fuel systems ran the same way as the 7.3s?... Y block to the heads then out of the heads into a reg return? And are the fittings in the same spot front and back, Basically like the 7.3?
