truckmaniac
- Joined
- Jan 16, 2014
- Messages
- 110
- Reaction score
- 0
My 2015 is tuned and deleted.
I just installed a new 50 gallon Titan Fuel Tank (replacement for stock tank).
The Ford Dealer can change the fuel tank capacity parameter from 29 gallons to 50 gallons, so that my Fuel Gauge and MPG Computer function properly.
The Dealer doesn't know if changing this parameter will have any adverse affect on my custom tune.
My Questions for the Day:
Do I have to return my truck to stock or can the parameter be changed without causing problems for my delete tune?
Is the fuel tank parameter re-set through the main ECM or another module?
I was thinking that I could drive the truck to the Dealership, flash the stock tune to the ECM (without starting the engine), have them change the parameter, re-flash back to my delete tune and drive away. However, I'm not sure if going this route will cause the re-flashed delete tune to over-ride the parameter set on the stock tune.
