6speedsd
Finally got a chance to hook my AE up to my dads 03. No dtc's which was odd considering my X3 showed codes for both cam and crank sensors, as well as a contribution code. Anyways, checked the basics. FICM voltages were spot on, ICP actual vs desired stayed consistent. Here is where I'm stumped. I set the rpms to 2000, clicked the box, and the truck only idled up to 1100-1200. No more. If I set it to 750, it jumped to 750 and held. No matter how high you chose, it won't idle up over 1200 rpms. I know the tach is working because it sweeps up through its range while driving. What would cause this? Only code that AE read was something about a "key in circut fault", or something along those lines. Don't remember the actual code.
