Steve's red stroker
Picking up a dana 60 from a 04' with a 6.0, does anyone know if the 6.0's front drive shaft will work in the swap as the 60 is a bit longer
really? i thought it was a direct swap also? you sure thats not a zf to a 4r swap?You'll need to shorten the driveshaft about an inch, if you plan to use the old one.
That's the only way I've found to tell the 50 from a 60 is the longer pinion. I swear that when I swapped my 50 to a 60 I stayed with my original driveshaft tho.
finger test works too..That's the only way I've found to tell the 50 from a 60 is the longer pinion. I swear that when I swapped my 50 to a 60 I stayed with my original driveshaft tho.
Thanks, but is the driveshaft the same from a say 03' 7.3 and 04' 6.0. I know when I sold a front driveshaft from a 01' 7.3 to a buddy that had a 03' 7.3, he had to have it shortened
