Dash Daq
Purdue_stroker
Ladoga, IN
I just got my spartan in and I'm gonna put it on soon. Ive been lookin through everything. Do I need to buy the ford license through drew technologies to have all the gauges? I want boost, egt, tranny temp, and fuel pressure
91turbogsx
Gardner MA
If you bought it from Spartan you should already have all that loaded on it.
You won't get a proper EGT reading without doing an EGR delete that has the bung for an exhaust sensor just a FYI.
91turbogsx
Gardner MA
Then you should be good to go. I do believe you will have to email them at Spartan though with your strategy codes and some other information before you actually get your tunes. Once they get all the info he'll send you your tunes to be loaded onto your SD card.
You won't have to contact Drew Technologies.
Strokerguy
Louisiana
To monitor the EGT's when you do the EGR delete you have to use a probe out of the exhaust. The one that was in the EGR won't work properly!! Good luck.
