Decking Heads
groove
Okanagan BC
OK, real world stories how much can you take off the stock (6.4) heads? I've read all there is on the 6.0, but that's not what I'm building.
What is the factory piston to valve clearance? I should add that my block has not been decked.
Thanks in advance
B585Ford
WV
Pretty sure 0.004. IIRC I had 0.003 taken off mine without any iisues.
UNLIMITED_DIESEL
Bremen, Ohio
From my experience you can cut more off the head than Ford specs, but you have to make the necessary adjustments to valve recession (valve job) and valve stem height if you do. Just my .02 cents.
cfdeng7
CT
It's an overall head height measurement that determines how much can be removed. There is variation in thickness even with new heads
Sent from my SCH-I535 using Tapatalk 4
91turbogsx
Gardner MA
I've noticed some heads new (reman) from Ford are already below their spec for overall head height.
groove
Okanagan BC
They are getting the full meal deal, experienced guy doing them so I'm sure I wont have issue but just wanted to ask the question. Makes sense with the overall height vs material removed.
