Def fluid monitor?
Enzo
On a 2013 xl f250 is there a def fluid screen to monitor the percentage?? I tried everything and looked in the owners manual with no luck?
sagebel
East Chatham, NY
You will get a warning with 800 miles remaining. If you do a system check it will tell you "OK" or "XXX miles remaining"
DTL
Bakersfield, CA
No percentage (unfortunately). When the truck says "less than half" on the display, even though the book says it's a 5gal. tank, wait a while before you try to put a 2.5gal. jug of DEF in it or you'll end up with a quart or so on your boots. :(
Enzo
i am having some throttle issues/ loss of power read some nightmare stories online i am hoping its just a def fluid problem? just dropped the truck off at the dealer will find out soon.
Enzo
yes i added 2.5 gallons and its still did the same thing the truck is a 2013 with 40k miles
Enzo
the dealer told me it needs a regen most likely?? we will see what happens my ford service department is really backed up so i gotta wait a few days
