West Point
The Library
1999-2015 Superduty Series General
Definitive Transfer Case info?
[QUOTE="co04cobra, post: 1185216, member: 666"] All t-cases behind 99-04 4r100s will interchange esof or manual shift. 99-03 Zf-6 transmissions (minus 6.0 zf-6) all t-cases will interchange esof or manual shift interchange. Neither trans is "bolt on" capable for a t-case in those years. 5r110 and zf-6 starting with 03 6.0 through 2010 all use the same t-case and spline count. All interchange esof or manual shift. 5rs are all bolt on 4x4 capable. Starting in 05 gas trucks all use the same t-case 11 up (I haven't changed as many of these yet) but all seem to interchange. Doesn't seem to matter gas or diesel. All 6rs I have encountered, or that we have performed 2wd to 4wd swaps on, have been 4x4 bolt on. Starting in 08 you can very rarely see a truck with a slip yoke rather then a flange on the tcase. That is all from personal experience interchanging them. Not saying you couldn't occasionally, I suppose, run into a odd ball but all of the above is what I have encountered. [/QUOTE]
C
Latest: Cazador
Today at 1:46 AM
Sunrise Ford Parts
Lower coil spring pad bolt
Latest: KBMKVIII
Yesterday at 7:14 AM
Latest: 6.0 Tech
Yesterday at 12:34 AM
7.3 Aftermarket
B codes vs hybrids
Latest: Charles
Monday at 9:54 PM
7.3 Aftermarket
B-Code VOP
Latest: Charles
Monday at 9:29 PM
7.3 Aftermarket
DEEZUZ
6.7Bison
West Point
The Library
