Deranged rebuild, the next chapter
bigrpowr
<How I Fly
Administrator
I should also note that this is the first time the ranger has had any work done to it outside of my shop since I have owned it. It was kinda rough to sit back but I knew nothing about what they were Doing so I just took notes LOL
most 4 link setups have a pro , at the track, watching until you get the setup dialed. I know I woulda had someone from CA or somebody qualified to get it dialed in. iirc there's 270 points of adjustment .
ChattyCathy
there is NO WAY it could have been , it didn't make any power. I think the rule of thumb is ONCE you make the power range, then you dial it.
The lightning did the same stuff with the 7.3 compared to the cummins. It was just worse and faster lol.
Strokersace
Towanda, KS
Good to hear Matt. Is that an old Fairlane in primer? When I was at the shop last there was a long fiberglass funnycar chassis and body in that spot. Late 60s mustang styling. It was sweet.
Sent from my XT1080 using Tapatalk
TPD286
There are a few chassis programs out there that will help with setting up and adjusting. Just takes time and a lot of measuring. Different tracks you will have to set it up different. Just keep good records.
Cutting-Edge Diesel
Newkirk, OK
Last night we Ran a 10.0@136 on fuel
9.59@143 ans 9.61@145 on spray!
Last pass we were at 145 hitting the rev limiter at 1000'
Need a regear or taller tire. Gotta crunch numbers to know what way we wanna go
