Diagnosing with dual pumps
Jonnydime
So even with a single pump and stock injectors it still does it? Is it bypassing inside the pump or returning out the injectors through the heads?
6.4 Stroker
Rapid City South Dakota
It's basically back to stock fuel with a lift pump now.
I don't think is bypassing, but I don't know for sure.
Basically I start the truck and it idols absolutely perfect. Then for whatever reason when I get around 10k rail pressure, pulsewidth maxes out at 3.0 rail drops to 1.5k and the truck bearly runs. But as soon as I let off the throttle its as if there's no problem.
6.4 Stroker
I think if I could figure out why PW is maxing out I could find the problem.
So right now I'm thinking I got 3 potential problems.
1 a bad engine harness?
2 a bad sensor somehow causing pw to skyrocket?
3 a bad computer?
madman1234509
mayfield, ny
Have you changed the pump harness and any wiring that may control the pump?
I guess my next question would be what sensors are utilized to increase PW, that may be freaking out?
6.4 Stroker
Yup pump harness, and pump gasket are new.
Still need to try a new under valve cover gasket on the passenger side. Also might try my buddy's spare main engine harness.
As far as sensors effecting PW I'm not sure witch would.
Mesa, AZ
Crazy out in left field thought, but figure id throw it out there as the uvc harness has been recommended, but are your ebp and map sensors reading roght? Could be it starys to dump fuel trying to increase ebp or map. Also, does low pressure stay steady? Maybe somethin floating in the tank and plugs the pick up, or a kinked line or something, rsstricting flow either to the low pressure pump or to the hi pressure pump...
6.4 Stroker
Thinks for the input.
Backpressure doesn't stay as consistent at I think it should so I'll check that out. Hopefully something will turn up.
Picked this up too.
bigrpowr
<How I Fly
Administrator
Thats Crazy.
I'm gonna go after the actual engine harness next.
Gonna figure it out one way or another.
i feel your pain homey . i chased a really random starting issue recently .. my truck would f'ing start prolly 1 out of 50 attempts . starter passed, everything passed. i swapped the shifter, adjusted the linkage on trans, chased everything. at a glance i said , F it , ill swap the starter for giggles , even though when it turned it was perfect every time. pulled starter , and a stud was loose . i know its not the same thing , but it was a huge pita . damn electronics i tell you .
