Diff fluid change w/ Royal Purple. Add extra friction modifier?
Mwilbur516
I'm about to change my diff. fluid and I'm using Royal Purple. It states that it already has the friction modifier and I wasn't planning on adding any more until I got to reading a post on the .org that states even when a fluid has the friction modifier you should still add more. Is there any truth to this? Has anyone changed to Royal Purple without adding anything and had any problems?
Spastik monkey
Tulsa, OK
it's all up to how the diff takes it. change the fluid with RP, and drive it. If you don't feel the rear end is working as it should, add some modifier. RP varies truck to truck on how well their included modifier works
Mdub707
Mohawk NY
I haven't heard/read any good things about the RP fluids. I'm pretty sure there was a guy on PSN who did quite a few oil analysis samples on his rear end fluids, as he towed heavy all the time and the RP did NOT fair well at all.
As for the friction modifier, I can't believe it'd be correct right out of the bottle. Most of the Ford rear-ends I've had to change fluid in that required the LSD additive, didn't require as much as typical LSD's. So some are different than others, how can one bottle cover them all?
Mwilbur516
I was looking to use Royal Purple because of the reviews I read online and in magazines. Personally, I've always used Mobil1. I'm open to any and all suggestions on fluid type. What are you guys using and liking?
wetnsloppy4x
Notus, ID
I thought all the friction modifier did was make it spin one tire more than the other.
Lol. Seems that way sometimes. Its really meant to let the clutches slip smoothly instead of chattering when turning and such.
I recently put in the Valvoline synthetic along with two bottles of Ford friction modifier. I have zero chatter turning and the limited slip locks up nicely in a straight line. Even on 37"s. Time will tell how it holds up.
This is on a diff that has about 80k on it. The diff it replaced had 100k on it when I sheared the pinion. That one, with it's original fluid, was a one tire fire from hell. It couldn't posi up to save its life. It had been that way since I bought the truck @ 53k.
I guess my point is the way the diff behaves probably depends more on its history than what brand fluid is in it.
Mwilbur516
Alright, I think I'm goin' to pick up a couple bottles of Ford friction modifier, but I found to different part numbers. Anyone know which one it is? Here are the part numbers I came up with-
M-19546-A1
XL-3 135454
Zmann
Manufacturer: Ford / Motorcraft
Item Number: FOXL3
us the modifier only if you get a chatter around a corner it actually free's up the clutches and since your using RP and your clutches are probably worn you may not need it
also if u even open the bottle triple bag it in a sandwich bag
this will be the stinkiest fluid you ever smell IMHO
Mdub707
Mohawk NY
Amsoil and Schaffers seemed to get good reviews/analysis. I'll see if I can find the thread...
Mwilbur516
Good thread Mdub. I'm gonna look into the Amsoil instead of RP. Just gotta find somewhere that sells it. I'd like to find it in stock somewhere.
Zmann
good call
thats about it x 10 .
I wouldn't be spending all kind of time looking for fancy fluid
ford or IIRC mobil 1 have the spec'ed viscosity in a syn and it is just fine
Mwilbur516
Having a really hard time finding the Amsoil, and where I do find it the dealers want me to order 2 cases. Not happening. I looked into the RP a little more and kinda doubt I'll go that route.
My cousin is a dealer. If you want I can give you his number and he will take your info over the phone and have what u want sent to your doorstep.... also I'm sure there's a few vendors on here that will send u what u need also.
