Difference between 08-10 and 11up?
02bigstrokin
Can anyone tell me what the difference is between the 08-10 super duty suspension and the newer ones is? Fabtech lists their lift kits for 08-14 as the same kit but none of the other ones do. Will a 08-10 lift kit work on a newer one? Thanks
11+ rear springs are longer and use flipped u-bolts (different u-bolt profile). the blocks are the same though.
as far as the front goes, i didnt see any difference.
Aaron S
08 and up use the same length leaf springs, but yes the U bolts are flipped on the 11 and up trucks.
