stroker221
#DPCCONVERTERS
Yes I know I know haha. Trying to hold off until after I can get some much needed fuel
#DPCCONVERTERS
Geeearhead race and a triple disc tc from Russ moore. Not sure who builds their converters though...
yes, you want the converter to engage quickly to cut down on wear but you don't need to be earth shattering at light throttle
it all depends on tuning
yup, if you WANT, you can make the converter absolutely rattle your teeth on lockup, S wrap the leaf springs on every part throttle shift, etc.
But good tuning only bangs the gears really hard at WOT. The first time you mash it on a big race tune prior to relearn, it REALLY hammers.
bump this back up.
So would having the TC lockup more firm than normal, hold a little more power?
I just rode in a all stock 2WD CCSB flatbed 3500 09 6.7 cummins and I think I know what the OP is talking about.
to me I think at about 2800-3000 rpm (4th) its out of the power band makes the 5th gear shift drops back in the power band and the TC locks and you pull back in your seat.
I can say for bone stock that thing has a strong bottom end (feels like a tuned 11-14 6.7 bottom end) IMO.
Raced my buddies stock 15 6.7 F-250 CCSB 4WD PS from a stop boosted launch, we both launched even and we both gripped and the cummins pulled away, at about 65 the 15 slowly creeped by.
I recently had a similar conversation with my buddy who just freshened my trans... this was my interpretation.
Generally speaking, the smaller displacement Cummins doesn't make the torque down low like the larger v8 does. If the apply is equal the higher torque motor will 'feel' softer. From what Ive been told, there is nothing better inside a RE -based converter vs. 4R or 5R.. the RE is old school like the E4 with on-off apply.
Also, the stocker 4R or 5R uses the pulse width (PWM) apply so it feels softer, and so its more flexible in tow conditions to keep engine speed up. However, once its tuned on, the TCC apply is often goes from 0 to 100% fast to protect the clutches under higher power conditions. Using AE, you should be able to see the apply rate. At part throttle conditions, TCC apply is more noticeable (not aggressive) than at full throttle.
but the biggest thing is that with most 4sp dodge tuning, there is zero torque converter apply until 4th gear, and then you actually feel ALL of that Cummins torque in the highest gear where it's at its greatest. so it's like "WHOA!!!!"
