bng305
2003 F250 5.4L CCSB. When the driver's door is opened, the interior lights and cargo lights stay on for around 5 minutes if the truck is off, and a little less time if the truck is running after the driver's door is closed. When you close the door, the door ajar light on the dash never goes out. The truck doesn't have automatic lights, just the turn/pull dial. The only door that causes any lights to come on is the driver's door, none of the others do anything. Is there a way to replace the door-ajar switch or is it easier to live with the lights staying on for a couple of minutes?
