Door ajar switch
FL
On my 95 F-Superduty the dome light doesn’t work when the drivers door is open. I replaced it with a motor craft switch with no luck. I pulled as much wiring as I could out of the door jab to inspect and it all Looked good.
Passenger door switch works fine and fuses are good. I’m not getting any power to the switch on any of the legs. Any input is appreciated.
79jasper
skiatook, Oklahoma
Burnt pins/wiring. (Like actually unplug it to inspect)
Actually I now see your passenger side works fine.
Could just be the wiring then.
Sent from my SM-G988U using Tapatalk
Parker, TX
Courtesy Lamp Diagrams attached. Cheers!
  • 089-001 Courtesy Lamps.pdf
  • 089-002 Courtesy Lamps.pdf
