Will newer model door panels, say 2013, fit on the doors of my 2005? Or would it require modification? The cab itself looks similar on all years of superduty so I wasn't sure.
A lot of the interior changed and I am pretty sure they wont fit, but thats really just my best guess. Even if the door panel swapped out, i doubt the connectors for the new window switches are the same, same for the mirror control's, etc.
If one took the time to de-pin the connectors it's easy to make connectors/switches work. You would need to study the wiring diagrams to make sure the old harness supplies the same inputs. OR you find aftermarket connectors that will hold the same number of wires.
I found some Deutsch connectors for a project and they worked great. Something like I used is linked below.
I believe there have been a few people who have done this swap, il look back and try to find some pictures. I believe IIRC the issues are where the panel hits the dash when the door is closed, and possible some of the mounting screws may be different. If you search around im sure you could find the thread where they were switched.
Do you know what the bulb number is for the 08 lights in the panels?
And is the main harness In the front door the work if you replace it with the 08 harness because in that picture I have one and the plug is identical.
I just want to do it to make it more clean and not spliced up everywhere. I know it's a waste of money but at least it's a lot easier to hook up. That I hope.
