door seal modification
Ridgeville Indiana
Just thought I'd tell everyone my results from my door gasket modification. I got the idea of Facebook. There was people discussing how poor the gaskets seal. There was a video posted where someone put rubber hose inside the door gasket. So I went on eBay bought the hose and did this for myself. It made a noticeable difference. The cab seems a little quieter and you don't hear the wind or feel the wind like before. So I just thought I'd give everyone. A heads up if your disappointed with the door seals like I was.
MEDIC350
Michigan
i did it myself the only thing i don't like is having to slam my door shut. thats going to take a beating on the door panel for sure
Yellow1000
eastern MO
In my case having an 09 now instead of a 14 like I had , new door gaskets aren't that expensive are they?
leland88
Warman Saskatchewan Canada
It expands the seals to make them slightly larger to seal better. I did it to my truck when it was new and it just eliminated wind noise
Sent from my SM-G900W8 using Tapatalk
Yellow1000
eastern MO
Makes sense. Just going to an older truck you sure can tell a difference in noise
Stangr8cr
I've done this as well, biggest concern is teaching the women of the house that the Expedition and Mach 1 doors don't need to be slammed like they owe em money!! Lol
Keith
Jassman
MS
I did this on my 11, 230k miles later not a problem and after about 3-4 months it ended up softens up and becoming easier to close. I notice a good difference on my 11, and will be doing this to my 15.
I got this off another site from Epic Cowlick...good guy that did that video and a few other helpful mods. http://www.leisurepro.com/p-aqu2012r/50-ft-roll-3-8-95-mm-surgical-tubing
mandkole
Northwest
it does produce results, but its amazing that a 4 year old truck needs these kinds of mods. Ford needs to be proud of their cost cutting efforts.
Arconalloy
Warner Robins, GA
What size wall thickness did you use the 1/16?
holy crap i need to do this bad. only thing i would have to worry about is the p.o.s sun roof sealing the wind out.
UNBROKEN
This mod is as old at Super Duty's are but I guess it still works.
