Double Shot Water Methanol Injection Kit
JDub
Hooper, Utah
Barely used Banks Double Shot water methanol injection system for the 7.3L and 6.0L Powerstroke. Installed it early this spring in a 2005 F250 and had great results from it, really helped with EGTs and power while towing. Truck is being sold so it's been taken back to stock. Complete kit, and looks like new still. Has a 7 gallon tank for the bed, high pressure pump and two injection nozzles. I have a couple gallons of the Banks Methanol blend you can take with it too.
JDub
Hooper, Utah
Yes it could be, but it gets its boost signal from piggybacking the map sensor harness, which I believe is different in the 6.4. So you'd have to trigger off egt only I think.
08Monster
That wouldn't be so bad. I'd want EGT and a push button activation to hit it when I want. Does it inject both at the same time?
JDub
Hooper, Utah
No, they are fully adjustable and can ramp just a little volume and increase as demand required
