driveline clunking
tomcon95
Rounded splines. Larges gaps inbetween splines. Not tight on splines.
Sent from my SM-G900P using Tapatalk
lariat 7.3
When I greased it I took a look, nice sharp square edges
mandkole
Northwest
Id also still pop the rear cover off.. its a hassle, but Ive seen broken teeth cause bind/release issues. Have a buddy look inside while you are moving the shaft. Eliminate everything.
lariat 7.3
How much play if and should be in the pinion up and down
tomcon95
It may be time for bearings, possibly a ring and pinion. Not something that should generally be done at home unless you know your stuff. Might be a good idea to find a reputable mechanic that is know to work on rears and have him take a look
tomcon95
"He" could also be wrong. I'm a mechanic and we do rears at our shop. We get alot of people sent to us from other shops because the other shops dont know how to properly set up a rear. Im not saying you mechanic doesnt know what hes doing but a second in person opinion never hurts. Its had to see much from the video ther than theirs alot of driveshaft slop and it looks like you carrier bearing is clunking. Sorry man but it might be time to visit the mechanic
lariat 7.3
I'm gonna slap a go pro under the truck and see if i can catch what's going on
