stroker2
Alright so i recently bought my 06 f-250 in which the dealer installed i believe a 4" lift on it and 1" block stacked with the factory block :wtf: (sits about an inch higher in the front than the rear with this setup). It was installed new before the original sale. I was told that it is a pro comp kit. It has radius drop brackets on top of what looks like factory radius arm mounts. It also has a trac bar drop and front sway bar drop brackets.
I want to lower this down to a 2.5" leveler. I believe i can do this by removing the radius drop brackets and using what i think is the factory mounts. Dropping the front down would make the trac bar drop mount interfere with components and i cannot find a leveling kit that includes a trac bar drop mount or where i could find an oem one for that matter besides the stealership. I know i will have to get new coils so i figure i would use these:
http://www.pmfsuspension.com/Icon-Dual-Rate-Lift-Coils_p_46.html
Any input and help would be appreciated! Thanks!
