jimdawg185
- Joined
- May 22, 2011
- Messages
- 1,869
- Reaction score
- 0
I've got two engines, trans, t case and a hundred other things I'd like to vacate from my garage. Chris put the complete engine together.
I will deliver this nearly anywhere
Two engines, both capable of well over 1k
One is disassembled, one is just missing a pump, turbos, and machining to the ATI damper.
The assembled one runs perfectly if it had a pump on it.
Extra pistons. Fire rings, extra ATI adapter, billet pulleys that need machining, p pump adapter, 4R100, t case, billet adapters and billet flywheel from Carson Stauffer (2500$ just for these three pieces from Carson). And a ton of ancillary stuff.
I don't need the money so don't waste my time, I'll make a great deal to the right person. I want this to go to a good home. And I will help that person get it in their truck any way I can. It's not a turn key deal. You will need fab skills. And you will need a good p pump to make power and some Cummins 12 valve knowledge.
Trans would need to be built for this torque monster.
Text me
616-460-9949
Text me
616-460-9949
