Dual led fogs
Rustedcutlery
So I have a non upfitter truck, and I’m going to add rigid fog lamps with kd fab brackets. Now I was told that the factory fog wiring will only support 1 light per side, and if I want to run 2 per side, I would need to wire it to a upfitter or a different switch.
Now I’m not so keen on adding another switch, I like things to look clean and refuse to cut my dash or have double stick tape.
So how about using my factory fog light wiring to be the signal for a relay, and run the 4 fog lights on one circuit via the relay?
Maybe someone smarter than me has a better solution.
Here are a couple pics of what I’m talk about.
http://www.kdfabworks.com/2017-F250350450-Dual-Rigid-DuallyBaja-Design-Squadron-Mounts_p_435.html
yes, use the fog light power to trigger a relay.
