CarportMechanic
My dad bought an Edge EvoHT2 at the beginning of this month. 4 times now the truck has stalled on him when driving.
The truck stalls when he gets on it to pass someone. First couple times he pulled over to check on things and can not see or hear anything out of the ordinary. Truck starts up right away if you cycle the key off then back on.
Last time it stalled he kept coasting, put in neutral and then started it up and kept going. Luckily he does not tow anything and is able to safely slow the vehicle down and control it to a stop without power steering or brakes.
He has had enough of it and is going to return the tuner. Truck is now set back to stock.
All this happened on the highest setting, I believe he said its a 80 hp setting?
Im curious if anyone else has experienced this issue? What is happening to cause it to just quit on him? Is he damaging the motor?
Truck is a 2011 F350 4x4, 27K miles. All stock except for the tuner.
