04cr450
Finally got around to installing an edge CS2 with egt sensor. Playing around with it- what pids do you guys monitor majority of the time besides egts?
Looking at the rail pressure, injector timing etc- not exactly sure what I am looking for as far as "in spec" numbers. Is there a cheat sheet on the board here where I can read off what psi's, temperatures etc should be at to the 6.7 operating specs?
