RazinCain
Ive been reading on the net about the EGR systems on these trucks. Finicky if Im reading correctly. I just aquired a new to me 2004 FX4 supercab 6.0. It does have 160K on the clock but it hasnt ever had a fifth wheel or gooseneck behind it and the trailer light plugs had dust behind the door so I dont think its towed much of anything. It is a two owner truck and the previous owner was an older fella. Had the Oasis pulled and it just shows being in the dealer a couple times for recalls but thats it. Nothing major.
The dealer was supposed to replace both batteries before delivery. They only replaced one. Day 2 of ownership rewarded me with a no start in the form of the other battery being dead. I jumped the truck off and about 10 minutes later the CEL came on DAMMIT! Well, I went to the local Orielly's and had the code read P0405 EGR a Low Circuit. I thought it may be from the dead battery. I erased the code. 2 minutes later it was back on.
Got a new battery (so both are new at this point) at the dealers expense. I unhooked the batteries and let her sit for about 30 minutes. Started the truck. No CEL YAY! I let it idle for about 10 minutes and still no light. Just for giggles I decided to restart the truck to make double sure. CEL was back on. read the code, P0405 EGR a Low Circuit. I checked my ALT for voltage at idle 13.95ish. Checked both batteris at idle 13.64. Checked the cables intermittently and it read 13.64.
Im going to pull the EGR and clean it tonight and check for a loose ground. If it doesnt turn the CEL off do you guys have any suggestions? It tripped 3 codes each time but they all read as the same one. Maybe I just "lucked" into having to replace the EGR (200 bucks!) the second day I owned it...
Is this something that needs to be addressed before driving the truck anymore? Just my luck LOL
Sorry for the long post and multiple questions. Feel free to slap me around if need be.
