littleredstroker
Just like it says. Auto meter gauges less than a month old . Pos and negative wires connected with the ones for trans temp gauge trans temp gauge still works. It's all off the same ground too. Was goin down a dirt road and it started wiggin out. Either reads 1100 degrees or 0 connections are good and wires are clear, no cuts. Any ideas or a way to tell if the gauge itself is bad
Sent from my HTC PH39100 using Tapatalk 2
