Egt gauge
1995f2507.3
I am planning on getting gauges for my truck I'm going to glowshift for there gauges, what one should I get they offer a 2400°F and a 1500°F meter, truck will be used for mainly daily driving use has 4 inch straight pipe exhaust on it
glow shift are garbage. Get isspro or autometer. 1500-1600 should be plenty for that truck.
Justin@DP-Tuner
:whs:
Many people have had issues with Glowshift throughout the years. A bad gauge is worse than no gauge. Autometer is my brand of choice for analog gauges.
As stated, 0-1600 is an normal EGT gauge for these engines. The temp range you should be in is 200*-1250* anyway.
1995f2507.3
I just didn't know where the 7.3 ran via egt wise, I thought they were under 1500, cost is the only issue for me which is why I was leaning toward glowshift
1995f2507.3
I'll have to investigate more onto autometer and isspro..
Justin@DP-Tuner
Koda22
Ruidoso, NM
I had glowshift in my truck for years, didn't really have any problems. I will say that one of the gauges didn't work when I first got them, but contacted glowshift and they fixed/replaced the gauge with almost no questions asked. Now I will say like other have said there are better gauges out there, but when in a tight pinch I think glowshift work just fine. I feel they are better then nothing, and then you can slowly upgrade as you can afford it.
1995f2507.3
They are a little bit more than more gauges but is touch screen and digital and can have up to 16 sensors in one gauge
gnxtc2
Bergen County, NJ USA
Autometer has a nice Factory Match series, except for the red needles (SD) with LED lighting.
Billy T.
[email protected]
