willholl79
My issue started off a couple of days ago on the way to work. I was on the interstate and the trans would not shift into OD. I eased on to my destination, cut the truck off, restarted the truck and it shifted fine, no more OD issues since. The next day I was going down the road and the radio shut off and on a couple times then came back on and all was good.
Yesterday, the ABS light came on while I was driving home. I stopped at the store to grab some beer and when I fired it back up, no ABS light. I made one more stop and back on the road, the ABS light came back on, the radio shut off, and the AC fan was on high, but barely blowing. I pulled over, shut it down, and fired it back up and everything was normal the rest of the way home. I'm not sure the OD problem is related.
After searching the web the possibilities seem to be:
1. bad alternator(it tests fine right now)
2. GEM behind fuse box wet from windshield leak
3. chaffed wire in steering column
4. acc. relay
Anybody here had similar issues?
4. acc. relay
