Engine block heater????
Dzchey21
wyoming
Good to know on that... I was wondering about that....
Will they send us a letter or do we need to call?
Repairshop
Not gonna send a letter. Not enough failures yet. One engine on youtube if you google it
I just replaced mine. Only 12 bucks each. Easy job intakes got access hole. Well plus i have a little less sh$& in the way. Haha
WHY NOT
Carlyle IL
The ect in the cooler not being connected will limp a 6.7. And make it run bad as well. It thinks egr is blocked or stuck open and derates. I guess thats why nobody deletes them
I believe plenty have deleted the egr coolers.
It's all about wheel speed and torque.
Repairshop
The 6.7 intake and heads flow air really well. Bottom is strong. Some retards in pa. Blew one up at 500 horse somehow. But h and s has a stocker with 600 goin strong. Thinking they know how to tune haha
Repairshop
Oh yeah they got cp4 fueling so that basically limits u to 475 like lml dmax. So duals are gonna be needed to break anything
Jhaddox
Negley, OH
Off topic but you do realize there have Been 6.7 trucks on stock pumps and nozzles snap rods..right?
Sent from my SCH-I535
mint-6oh
NJ
From the 6.7 Diesel Bible: Engine Block Heater
The engine block heater is located on
the right side of the engine block. The
block heater uses 110V AC to heat
the engine coolant in cold weather
climates. Use the engine block heater
must be used whenever ambient
temperatures are at or below -23°C
(-9°F).
The engine block heater is standard
on every engine. The power cord is an
optional accessory.
I haven't looked at my truck yet to see if it is there.
Block heater is not standard. I have installed several of them
sagebel
East Chatham, NY
Stupid documentation. :mad:
Is the install as easy as it looks. Thread element into block and install cord? How much of what type of fluid do you loose?
mint-6oh
NJ
Not much to it, remove plug from block and install block heater element. If your fast enough you dont loose that much coolant, or you could drain the cooling system and take your time
Repairshop
When i was a helper 25 years ago. It was my job to put block heaters in the gm diesels for pdi. I was pretty damn fast and still ended up soaked with coolant
