Engine Dusting
powerstrokenstang
Verona VA
filters are over rated..... lol. my puller has not had a filter on it in about 3 years lol. i do have a 6637 on my sd though, and my granddads had a k&n, never noticed dust in it. its got a 6637 now but the k&n was gettin old and didn want to have to clean it.
PsRumors
Cartersville, GA
Ugh...
People, its not the filter media... Its the sealing of the box.
Agreed its a K&N issue, but its not the filter media.
I have had the same AFE/S&B/K&N type oiled gauze filter for 7 years and 200k... NO dusting issues at all.
It's not just the sealing of the box....Lots of people don't understand how to properly care for an oil gauzed filter
CSIPSD
Bend, OR
True as well, but if you *** up the filter by drying it with compressed air... Thats not the filters fault.
Bruno2
Broken Arrow , OK
I either set them on the outside AC unit to dry or just let them sit on the work bench overnight and they dry just fine. Whenever I would buy a filter from K&N I would call them a month or so later and tell them it was coming apart. Then they would send me a replacement for free. This way I would have 2. One to swap while I got around to cleaning and oiling the other. I would store them wrapped in a bag in the box they came in. This way I didnt have to turn it around or buy a paper filter to use while the oil and gauze filter was being serviced.
sgleshot
idk, to each their own, but I run a K&N on my pro truck, idk if it pull as much or more than my 7.3 does being that it spends it like at 7800 to 8k rpm, but i had to run one of their diapers on the outside of the filter so it would help to pick up stuff so it would quite clogging the air bleeds in the carb. Yes I realize, somewhat comparing apples to oranges, but what im getting at is the material they use for the filter media without a doubt does let dirt, dust, whatever through. I'm not a huge fan or K&N, but there isnt much better out there for the application and they pay contingency on occation. I also love my 6637 for my 7.3!!
neverkickn
AR
Yeah I guess it is ok to do that since they are a big company and all :poke:
fordfreak4life
I pulled a K&N off a 2006 5.9 cummins 2 days ago because the guy was complaining about power.... needless to say it looked like the damn thing had been running with no filter... idk why anyone would invest in a dirt sucking oil charged filter for anything.... if i was running a race truck it would have an intake tube run as far forward as possible for a cool air charge with no filter... otherwise ill stick with my paper element filters..... they work
Dieselfever
Beaverlick, KY
My thoughts also :doh: If you are so adamant about how good they are then spending the money for a second filter element should not be an issue. Rather than being deceptive to get a second for free.
-Michael
Overkill
Firestone, CO
My guess would be improper oiling of the filter if its allowing dust past it. Never had dust past the filter in my dirt bikes, which live in dirt and sand. They are not force inducted, however so I'm not sure that's comparing apples to apples.
Bruno2
Broken Arrow , OK
-Michael
Since you are so adamently against them then why would you even care?
Mad Max
in, out and all around the matrix you live in
derail and moved to awol in 3....2....1...
gnxtc2
Bergen County, NJ USA
I have a K&N filter on my truck since new. I ran the stock replacement filter and applied grease around the edges of the filter. Sent my oil to get analyzed and it came back with 0 silica reading.
Before the Tymar set came out, I looked through K&N's catalog and got myself a large cone type filter and have been running that ever since. Truck has over 202K on it.
I still send me oil to have it analyzed and it comes back with 0 silica readings.
I tried the part filter and didn't care for it.
Billy T.
[email protected]
Aljay
Texas
I run a baldwin 2818 and it gets replaced once a year as does the panty hose I use as a pre filter .............. :D
OBSWIZ
Wellington NV
I've seen K&N's dust a turbo, A AFE Big mouth dust a turbo but never a Tymar-Donaldson.
Ask Quad, motorcycle and off road guys about K&N's..they will never use them ..haven't for years.
mortal798
Michigan
I can tell you from experience in a dealer shop (Lincoln-Mercury) that K&N caused all kinds of problems with the MAF sensors on gas engine cars and trucks. The oil would collect on the MAF hot wire and pick up dust that wasn't being filtered out. You would take out the MAF and look at the hot wire, it would look like it was wearing a fur coat. When it has a fur coat, it is insulated from the incoming air and it under calculates fuel.
I would never put one of those on any of my vehicles.
Aljay
Texas
The oiled elements have accelerated oil consumption on a few 7.3s .
Two friends have experimented with oil and non-oiled K&N.
