Engine light after turbo swap
Cody1898
Did the turbo swap on my 2011 and went with the upgraded turbo. Now i have a light. Sct shows these codes. Will just replacing the sensor fix it?
08Monster
Did you forget to plug in the MAF and the I AT sensor?
Sent from my Moto Z (2) using Tapatalk
Cody1898
I didn’t do the swap. The maf is on the intake correct?
Check the iat sensor on the bottom of the cold side pipe and make sure it's plugged in.
You didn't by chance install a 5" cold air intake at the same time didn't you? If you did, you need to get the maf rescaled in the tunes.
If you didn't get your tunes modified, you are eventually going to get the P132D and P007E codes as well. Get your tuner to shut those off.
Its common to get the high intake air temp one after a larger turbo as they move more hot air than the older turbos.
