Power Strokes
Excursions
Excursion body swap???
[QUOTE="Vader's Fury, post: 1487018, member: 473"] You can swap them. You basically will be swapping all of the wiring from the diesel to the gas body. This includes the dash. You can swap all of the parts of the dash between the 2 if there is a color difference, it will just take more time. Depending on if you will still use your original frame or not, you will need to swap all of the wiring and fuel lines on it as well. Not crazy hard to do as long as you have a lift to pick up the bodies and time. That is the hardest part of the swap is the time to strip both bodies down and put one back together. [/QUOTE]
C
Latest: Cazador
Today at 1:46 AM
Sunrise Ford Parts
Lower coil spring pad bolt
Latest: KBMKVIII
Yesterday at 7:14 AM
Latest: 6.0 Tech
Yesterday at 12:34 AM
7.3 Aftermarket
B codes vs hybrids
Latest: Charles
Monday at 9:54 PM
7.3 Aftermarket
B-Code VOP
Latest: Charles
Monday at 9:29 PM
7.3 Aftermarket
Power Strokes
Excursions
