Jeff@Spartan
Good info Shane! I've done a little reading up on it myself and that is basically what I gathered from it.
Okay Mike. But explain how the back pressure directly caused the failure. Mike please explain your situation cause I'm curious if you had an indirect ebp to hg failure or a direct ebp to hg failure. Not saying your wrong, just curious.
The most common way BP can attribute to a hg failure is by having higher drive pressure which increases the boost pressure thus increasing the cylinder pressure and what do you know the hg let's go. What was the reason for the hg to fail? It was the increase in cylinder pressure due to the incresased boost. What causes higher boost? Higher drive pressure or higher BP as most ppl call it. This situation is how BP indirectly causes hg failures.
I think we are on the same page Mike. Like you stated back pressure can start a problem and the scenario goes from there. But what causes the high BP. One a miss adjusted gate, 2. A undersized gate for the application, 3. A stuck gate. I'm sure there are other possible causes.
I think it's safe to say that BP doesn't directly cause the failure but it can definitely contribute to the problem if said engine is not setup to handle or control the increase in pressure.
Now Mike back to your situation on your 7.3. Your blaming high BP on the failure if I'm reading right. Fact is the failure was caused by a undersized gate which lead to high BP which increased your boost and thus your cp went up and bam the hg popped. So BP didn't cause the failure in your engine. The undersized gate was part of the problem and the other part ofthe problem could've been small exhaust housings on the turbos as well. Again the gate wasn't big enough for the turbo design.
No the failure is not due to back pressure. The failure is cause the cp got high enough to pop the hg. Your BP got high cause of a lack of an extra gate. This is how your situation went down. You put twins on. Had one gate that was gating overall. The small housings and only one gate caused your back pressure to go up. With the incresased BP your turbos added more boost. With more boost in the system your cp went up and bang the hg was ***ed. the whole reason your hg failed was cause the cp went up. Your setup was not designed to handle 75psi of boost. I guess it depends what part of said situation you want to put the blame on for the failure.
There's info missing Mike. Cause obviously the cp got high enough to compromise the hg and make it fail.
