F-350 DRW Wide Track Front Axle Question (tow boss)
Powerstroke Man 6.4
I got a 08 CCSB F-350 tow boss 4.30s 13,000 lbs gvwr etc etc.
Since its a short bed the option (67W) or the wide track was not available.
what makes it a wide track?
could you retrofit the regular drw dana 60 to make it a wide track or is the wide track a wider axle itself?
Thanks in advance.
Zmann
the Dana super 60 is the same balljoint dana 60 as the 05 up 250 /350/450
thats correct a 2005 F 250 has a Dana super 60 just not a widetrack
the wide track has different knuckles and shafts i believe the housing is the same length it's all in the knuckles that create the better turning and wider stance
Zmann
description = http://www.pickuptrucks.com/html/2008/ford/sd/fatboy/page1.html
Zmann
you can easily swap a widetrac unit to your shortbed
same axle found under the 450's the dead giveaway is the bumper flare and big ole fender flares but watch the lug patterns
