F-350 regular cab project truck. $6500
Motostroker
Bought this truck off a member on here but I have simply not have the time to complete it. My regular cab project is up for grabs
Looks like a mess butt however every nut, bolt, washer, etc is accounted for. Truck comes with the Trans (which I can throw back together the way it sits. The clutches are smoked) both motors one good short block with 180k, and the other motor is bad. It ate a LPOP. t-case, etc.
I can label each tub aware container with bolts, nuts, from each part of the engine for easy re assembly.
ImageUploadedByTapatalk1443564781.076136.jpgImageUploadedByTapatalk1443564793.781175.jpgImageUploadedByTapatalk1443564800.985090.jpgImageUploadedByTapatalk1443564810.289146.jpgImageUploadedByTapatalk1443564819.593646.jpg
I'll throw in a box of (torqued once) arp studs, it has a live wire, Intake, 4 inch exhaust, etc.
Perfect platform to build something since it's already apart. Go ahead and send injectors out. Stuff like that.
If you know how to swing a wrench this is the perfect opportunity to get into a truck cheap.
Body is 7.5/10.
Will need some brakes and rotors however the front end is relatively fresh and I'll throw a brand new ready lift track bar in with the deal also.
140k on the truck
$6500
Jason
Somewhere down in Texas..
I'm a fan of pretty much everything motostroker has turned out. I thought that was the truck, but couldn't tell from the current state. Wow...sad to see it in pieces, but that's a good deal for someone to get it back together and going right!
Motostroker
If it doesn't sell soon it's going to go under the knife. I sold my platnium today. All I have to drive is this 2000 TDI Jetta lol. I'll give it one week, if it doesn't sell in that time I will build it
what would the cost be if i shipped you a trans and complete running engine from fan to oil pan and got you to button it all back up?
