Factory spare tire lock?
Adamv7010
Went to drop the spare today and its got what looks like half of a wheel lock on it...down inside the tube.
Is this a factory item or something someone added?
None of my wheels have locks on them.
Glad I found it without having had a flat tire on the side of the road Lol
thanks in advance
Bobby@cp
Yeah they require a special key. Luckily my SD had the key in the glovebox
HOOV3R
Central PA
3/8s drive 9/16s or 14mm 12 point and extension + hammer. Gets it every time so far, but you wont get your socket back.
Bobby@cp
mine worked on his before which was why I didnt really wanna let him borrow it
Zmann
you can hit the dealer most have a set of keys
they will try until they get a match and then supply you with the key but it also needs the tire rods to fit onIIRC
Adamv7010
The lock doesn't come off, you rotate the tire down with it.
I found a few threads on here where guys did just this....lower the tire...then get in there , take the tube out and separate the lock from the winch....then the regular tube will work to lower and raise it
Zmann
Yeah I think they have serial numbers on them...
there are no serial numbers or vin match
the keys are color coded as far as I remember
ebay used to sell the whole master set cheaper than the dealer sold 1 key lol
sizeimage.php
Zmann
I also have read that u can do the work around with a socket and then remove the special lock part like mentioned
Zmann
but without the old key the color code or serial # is useless
ya think they would have a production date or vin way to match you up
god knows any one who wants your spare would have it without the key LOL
my GM truck was a tad smarter it used a matching door key spare tire access port locking cover
JMart
DFW
I have the whole wench assembly with the lock and from my 01 in the garage. My 05 didn't have the locking type. I thought about switching them out.
Zmann
I was told they were made specifically to the VIN... I had to have mine cut off cause there was no way to order one.
how do they cut a socket LOL ?
I personally went to the dealer they came out with a set of them ( can't remember how many ?) tried them until one fit
went back inside and they either ordered one or had one I don't recall and I was on my way ,, this is a big dealer and they could not just look it up by VIN otherwise I am certain they would have V.S spending 15 minutes in the parking lot ..
