Factory Stereo Removal?? 2008 F250
2stangs8689
Lockport, NY
Ok, I have searched everywhere, and have come across a couple different "removal lists"
Does someone have a link, or can explain exactly what needs to be removed from the dash to remove/replace the factory head unit?
Thanks.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
webb06
Seneca, MO
By using a flathead screw driver and prying out at the little slot. Should pop right out. There will be 1 7mm screw behind each little cover. After those are out just pull out on the dash piece all the way around. Be careful but it will take some force. You will need to undo some wiring connections to completely remove the dash panel. Once that's off you can remove the radio. Should be 4 7mm screws holding it in.
Hope that helps
2stangs8689
Lockport, NY
Awesome!!! Thank You Very Much, Webb, it is greatly appreciated!!
I found 4 different versions online, found nothing in my searches here, and only 1 of them was right as you have confirmed.
2 of them had me removing the vents!!
Thanks again!!
