JustDiesel
Good evening all, having a no start issue on my wife's 2004 Ex. The truck has banks exhaust and Edge CTS monitor but other than that it remains stock at 162k. We were traveling home the other night and the truck lost power and died. Truck indicated about an eighth of a tank of fuel so I assumed I had run out of fuel, I was able to restart the truck after it came to a stop and I drove it about 400 yards into a fuel station. I left the truck running refueled and continued home. 10 minuets down the road truck lost power and died again. At this time I had no codes on the reader but the FICM voltage indicated 0 volts. No luck on a restart so AAA drove us home. Since coming home have checked batteries, checked all wiring harness and connectors on FICM, replaced fuel filters and all fuses and relays for fuel system and FICM. I now get inconsistent reading from the ficm either 0 or 47.5v. Truck still doesn't start and after replacing the 50w fuses under the dash I finally got the following codes. U0105, U0306, P0001, P0603, so basically the truck isn't communicating with the FICM as best as I understand it.. I just replaced this ficm 5 months ago, is there anything else I can check before I pull it and replace it again?
