FICM low voltage
Tinbanger
Arizona
So I just installed a CTS monitor in my truck, and I was watching my FICM voltage and I saw it go down to 31 VOLTS while WOT! That doesn't seem right. It starts and drives great with no issue. Will this damage my injectors, or anything else?
F-250-Owner
Masontown Pa/Maputo Mozambique
Yes it will kill your injectors..... 31 is really bad. I would change it asap with an upgraded one. I run a 58v from quick tricks or you can get the half shell from a vendor here for 180 I think
Sent from my SPH-L710 using Tapatalk 2
Zmann
make sure your battery voltage isn't dropping at the same time
Tinbanger
Arizona
Normal driving it stays between 46 and 49. Just when I get on it hard, is when it drops like that.
Tinbanger
Arizona
Do you have experience with any of the FICM shells from the vendors on this site? Are most shells the same? Or which would you suggest?
F-250-Owner
I think the guy who sells them is thunderstruck but don't really remember. I run a quick tricks one in mine and its a good deal....lifetime warranty and decently priced
Stroker04
Gettysburg PA
You can also send it out to a FICM repair shop. They will fix them relatively cheap and usually come back with a lifetime warranty as well.
Tinbanger
Arizona
Thanks for the info guys, ill try to stay out of the throttle unit I get this fixed. There is a Bulletproof diesel about twenty minutes from my house. Maybe I can get a good deal there.
Zmann
your good deal will Be no shipping $ But paying TAX LOL
Zmann
Cheap ? the lifetime is just paying in advance to fix it again
$195 - Basic service with a 45 day warranty.
$225 - Basic service with a ONE YEAR warranty (your extra money is just buying the warranty)
$325 - Premium service with a TWO YEAR warranty
$425 - Premium service with a LIFETIME warranty (again, your extra money is just buying the warranty)
doubledrop
They have the best FICM around but it has a price tag to go with it. Although its def worth it
Mdub707
Mohawk NY
You can just have it repaired... I haven't seen any issues with any that I've repaired after...
Zmann
BPD only sells u the power supply side = no reprogramming necessary
unless you upgrade your repairs at say FICM.com your just as likley to have a failure as you are with a new OEM power supply
Repair Choices - warranties ranging from 45 days to as long as you own the truck!
We offer two different repair options on the hardware side - a basic service and a premium service.
The Basic service uses OEM grade components (NEVER just a re-solder job). For this service, we determine the issue with the module, replace the dead, dying, out-of-spec, or heat damaged parts with new OEM-grade components, test the module, and ship it back out. Of course, the use of OEM-grade parts sounds great until you realize that you are having this issue to begin with. Welcome to the basis for our Premium service!
The Premium service uses components that are of dramatically higher grade than the OEM components. Here again, we NEVER just do a re-solder job. As with the basic service, we determine the issue with the module, and replace the dead, dying, or heat damaged parts. The key difference is the use of the much higher-end components that have higher temperature ratings, higher power-handling ratings, etc. combined with the replacement of any components tested that don't test out as if they were new, basically going even further to resolve the original design challenges of the module.
Zmann
ask them how much to install
maybe you'll get lucky like I did
with the rain coming you don't want to do this for your first time outside
Mine was in 110 degree heat ,, they helped Me avoid that problem altogether
