Heavy_Duty
OK, I got an early 03 6.0 and will need my ficm replaced/ repaired due to voltage issuses. The question is can you replace the half shell (power side only) on an early 03? I was told you can only do that to the later ones, early ones you have to replace the whole thing and have it programmed. If I can't then I'll probably send it in for repair
