ficm questions
Heavy_Duty
Wichita KS
OK, I got an early 03 6.0 and will need my ficm replaced/ repaired due to voltage issuses. The question is can you replace the half shell (power side only) on an early 03? I was told you can only do that to the later ones, early ones you have to replace the whole thing and have it programmed. If I can't then I'll probably send it in for repair
makuloco2000
Pull both negative battery terminals before opening up FICM plate for inspection!
Here is the TSB, you have to check it to see if it can be half shell repaired, yes most early 2003 cannot be repaired.
Remove the two (2) Torx T20 retaining screws and inspection plate from the back of the FICM. (Figure 2)
Figure 2 - Article 10-12-6
Inspect the buss connector screws.
If FICM is an early style with seven (7) connector screws, do not disassemble. Replace the FICM assembly. (Figure 3)
Figure 3 - Article 10-12-6
If FICM has four (4) connector screws, proceed to Step 4 for inspection and repair. (Figure 4)
Figure 4 - Article 10-12-6
Mdub707
Mohawk NY
Just have it repaired. The 1/2 shells aren't any better than what's coming off of there, they will still fail again at some point. I have seen failed reman FICM's from 2010...
Heavy_Duty
Wichita KS
Yea, I'm getting one from ficmrepair.com for an extra $50 they send you one so you don't have to be down. You have 30 days to send yours back without a core charge.
squirtgun
I did the repair myself...it's straight forward and fairly easy of you know how to use a soldering iron.
Mdub707
Mohawk NY
They charge you $50 extra to send you one up front but don't refund it? Am I reading that right?
Heavy_Duty
Wichita KS
Extra $50 to ship one out so your not down. They charge you $300 if they don't get your old one back in 30 days. Normally you send yours in, they fix it and send it back.
weazel
Elkview WV
I sent mine in, truck was down for a little over a week, that was over a year ago, still runs awesome today
Sent from in a ditch up side down and on fire with the wheels still spinning
Dave
Bulletproof diesel has 4 and 7 pin half shells.
Ive been running a 4 pin since March of 2012. I love it
