Finally fixed the tall rear headrests.
UNBROKEN
It took a while to get the OEM parts but Sunrise Ford stayed with it until the covers came off backorder....took a month or so to find everything.
Anyway....I cut the stock foam along the support bars to get the support out, cut it down and re-welded it then did the same with the new center foam pieces, cut a groove in the foam for the re-worked bars to fit, glued it all back together with our industrial grade spray glue at work and covered them with OEM covers. Now I like them.
In short, I modified two center foam pieces to take the different sized outer support bars and recovered with OEM center covers.
It's about $340 worth of parts but worth it to me to have all OEM stuff back there.
Hell yea. I was looking at pn to do this to my old truck that has NO headrests :doh:
Towerguy
Woodstock, GA
Nice! I thought I was the only one who was bothered by the looks of those surfboards sticking up back there. I'm thinking about updating the seats in my truck to the 2011+ with a matching backseat and have been pondering my options.
UNBROKEN
Why wouldn't you be able to purchase two more center headrests and put them on the outer seats?
That's basically what I did. The posts are different though so you have to combine parts from the center and outers to make it work.
dsberman94
Pennsylvania
Ok. That makes sense. I was just wondering. Never even been in a 6.7, no less messed around with little stuff like the headrests. Haha. Looks much better now though.
Everytime i see one if these i think "might be better to ditch the center rest"
bad ass.. same color as mine.. send me those and you can do another set for yourself!!! i am about to just take them out all together!
Jomax
Arizona
340 is not bad. I'll have to add it to the list, that center seat being smaller is all I see now because of you.
Can you take the center one out? More visibility and who gone sit in da middle?
shmoozer
First thing I do in any of the 6.7's I drive at work is take that center head rest and chuck it behind the seat.
This looks 100 times better than factory.
-KCCO-
BK39
Texas
Looks good man, you def have attention for detail. A little OCD compared to most, but hey it works.
Yes, I remove mine when we have the beer cooler in the bed of the truck. It's the only way you can get through the tiny window to get beer!
