SDS97_7.3
Sorry we lost a few of you on the way lol
I'm running late but will see y'all there. Headed out now
Ill get you some and bring it to BTK's dyno day..![]()
I want Sakuras too! LOL
Found the problem... snapped the axle shaft bolts on the hub... all ****in 8 of them... hopefully theres a left hand drill bit set at the shop
When was it pointed out they were loose? Im not followingDid you ever tighten them after it was pointed out they were loose?
They kept doing it after that ao i kept tightening then replaced the bolts a few months back and have been fine since... not anymore i guessI recall someone or another pointing out to you that the bolts on both drive flanges were loose and backing themselves out when you were parked at Jimmy's shop.
Did you ever tighten them and if you did tighten them did you ever re-check them?
Lol :flipa: he did that in sakuras parking lot lat night hahahaHe's not old enough to rent a car dude. Lol
Do you have left hand drill bits? I'm already otw or id bring my drill and left hand bits.Lol :flipa: he did that in sakuras parking lot lat night hahaha
Tracking down new bolts now. Then limping it to the track and praying corsilli was right and they have a drill there i can use to extract them
We found extractor bits and a normal bit. Hoping it works. Ive only used left hand drill bits before not theseDo you have left hand drill bits? I'm already otw or id bring my drill and left hand bits.
Ok. You should try to find nuts to weld on and somebody with a welder if the extractor doesn't work.We found extractor bits and a normal bit. Hoping it works. Ive only used left hand drill bits before not these
If you have a handheld drill bring it. Left hand drill bits too if you got themZac do you need me go grab anything? Late start I haven't left the house yet. Or I could just text you..
Cool thanksNo bits but I'll grab my cordless and the charging base
