Fluid leak
vvance
There's a faint smell of antifreeze after engine is warmed up around the front. No puddles on the driveway but after crawling up under it I see this. It's coming down from the rear of the engine on both sides.
Anyone else had this problem?
Sent from my Pixel using Tapatalk
pull the upper and lower intake manifold off, takes about 10 minutes. my money is on the coolant feed line to the turbo.
Mesa, AZ
:whs: i replace the line at the same time. While you have the intakes off, may want to do the oil fittings and line as well, as they are fairly common to leak as well.
