Forces and icon lift
Bigharm27
Hey guys my 22x10 forces and 4.5 icon lift are gonna be arriving soon but my only question is I see all these guys running 22x11 and the offset on a X11 force rim is less. Will I still be able to clear 37x13.50 with just minor trimming. I just figured that a x10 rim would have less offset. Any input would be awesome and thanks
mwdguy
Edmonton, AB
I run 22x11 forces on 37x13.5 with 5.5" icon. I have pmf traction blocks though to move the rear axle forward as i rubbed the flares when I hit a huge bump on the hwy. the front needs to trim the bumper bracket. And the tires will rub the radius arms a little.
Bigharm27
So is the X11 even wider? How can a x10 be wider and require more trimming than a x11?
Bigharm27
And what would need trimming on the front. I'm gonna take the bumper brackets off but on the back side of the wheel what do u need to trim
VetteD_SiN
the offset. 11s run a 0 offset. 10s run i believe a -19. conversely, my 12s is a -44 and my 14s is a -70. all equate to a 4.75 bs. 11s equate to a 6 bs. when i was 6" i would rub my mud flaps. other than that it was good. my tires is 35s. at 37s with a less than 6" youre gonna rub somewhere.
powerstrokedkid87
New Jersey
your -19 will stick out slightly the difference in the x11 vs x10 is the distance from the center of the wheel to the inner lip. The 11s are wider, but the offset is more centered making the wheel not stick out as far.
bruce65trojan
37s on 22x10 and 4.5" lift is going to be too much. Even 37s on 22x11 will rub with the 0 offset.
That's why I went with you man! You had already put that on a truck and knew what you were talking about.
Bigharm, I thought when you messaged me you said you were going 11's?
znunez72
Lee's Summit, MO
I currently run the Carli 4.5" with 37/13.50/20 R/Ts on a Trail Ready 20x9 with 5" of BS and only rub on the driver side radius arm at full lock or when articulating pretty good.
Bigharm27
I have heard that one certain brand of fender flare can give me some extra room. Is that true?
