Forscan. What is it
TrickTruck
Simpsonville, SC
ckrueg
Belding MI
Is this the answer to oversize tires? My next tire is going to be the Ridge Grappler in 37" and this seems to be an answer to compensating for tire size.
https://docs.google.com/spreadsheets/d/1w7rPx4RE3Sxa8UJj4sQAG5WktnI53wRu45y-gMmuzJY/edit#gid=0
yes,no?
If I understand it, when I convert a inch to metric and put those numbers in there this hex number is the one for those bigger tires.
If you go much over stock size of 275/65/r20 it will throw codes.
BigRed97
Saugus MA
I tried converting my 37s to hex and inputting it with forscan but it wouldn't write, came back with invalid or something...did the same on my buddy's with 35s
JetExpress_6.7
Yes you can only choose from a pre-defined tire size list in the module. Get as close to your aftermarket tire size as possible and call it good
ddppff% clogged works on the standard dash. got it to show up on my formans 2013 6.7 yesterday.
PDT1081
Bowling Green, OH
Is there more of a write up on monitoring w/ an android device? I can't seem to combine two or more different groups in the monitors. Like bdy/tpms info and pcm output on the same screen.
Lots of good data there though.
Seems like a cool device and can only get better w/ time
Are you using the free app, or did you pay for it?
JetExpress_6.7
that's a shame :(
FWIW, you could also change the gear ratio to accomplish correct speedo readings
Get the tire size as close as you can, start moving the gear ratio down towards the tall side and find a happy median. 3.31 is the tallest I'm pretty sure
ckrueg
Belding MI
Have you tried this? From what I have read, the way ford's read speed is not affected by rear axle ratio.
JetExpress_6.7
Have not tried it...sorry! I may have spoke too soon, didn't realize that
Worth a shot tho
