Front coil spring question
Bigcountry250
One thing I've noticed about my truck is the front sits lower than every other F250 I've seen. I know the guy before me special ordered the truck, is there an option to get a lower front end? I don't really want to do a spacer, I'd like to find a little bit taller spring and swap them out. Any suggestions?
check the sticker on the drivers door pillar. the front axle pound rating will tell you what springs are in it. if it has 4800lb springs you can get some 6000 lb springs and it will lift it a bit.
there are a couple of dealers on here with good pricing.
depends what spring you order. There are 2", 2.5" or 3" i believe
Super Stroke
I have a set of 6000 springs laying around I would sell. I took them out to put in an Icon lift.
not a whole pile. check the classifieds, there is a zone levelling kit with shocks for sale.
Bigcountry250
Icon has 2.5" springs for $424. I really want 2" taller springs, anyone know where I can get those for less than that?
Dzchey21
wyoming
From the reading I have done 6000 to 5200 should be about an inch to 1.5 difference. Can't get a for sure answer. Either way I would like to have your 5200 lb could when you figure out what you wanna do
Bigcountry250
You want to do a straight up trade?
Dzchey21
wyoming
I would only problem for both of us is having an extra set of springs to use in the mean time for shipping. Let me see if I can gather a set up
Bigcountry250
Yea that would be a problem bc this truck is my only vehicle. Let me know what you figure out
