FS: Bilstein 5160s for 05-up w 4" Lift
BBottoms
Buffalo, KY
Used set of Bilstein 5160s I took off my truck. Had these on for around a year and a half and 20k highway miles. These were on through a couple winters so the brushed aluminum finish has some surface corrosion accordingly. Should clean up pretty well with little elbow grease. They all still function and cycle fine and the mounting points are all in good shape. Shafts are nice and clean with no corrosion or nicks. When I removed the shocks one of the rears had lost all dampening so it just came back from getting fully rebuilt by Bilstein. They installed a new end cap with a schrader valve on the reservoir as you can see in the pic.
Fronts: 25-177435 for 05-14 w/ ~4-6" lift
http://cart.bilsteinus.com/product/25-177435/207932/4WD
Rears: 25-177442 for 05-14 w/ ~4" lift
http://cart.bilsteinus.com/product/25-177442/207932/4WD
$450 OBO
BBottoms
Buffalo, KY
I think the top mounts on the older trucks are different. I'm sure someone makes an adaptor though.
